Engine stand for Aerovee assembly
Postby Bryan Cotton » Mon Sep 08, 2014 5:15 pm
Hi all,
What did you use for an engine stand? Two or four arm? Bench mount or on wheels? Harbor freight or anything else? I saw in an old post the Mike recommends CB Performance or Aircooled.net.
The primary disadvantage I see of the 4 arm is you would have to assemble the case before you mounted it up to the stand. Is this right?
Thanks for the feedback!
Re: Engine stand for Aerovee assembly
Postby Sonerai13 » Tue Sep 09, 2014 9:19 am
We just use a couple of 4x4 blocks about 14 inches long (give or take) to set the case(s) on and do it on the bench top.
Joe Norris
Sonex N208GD (S/N 450)
Sonerai II N13NN (S/N 1206)
Fortes Fortuna Adiuvat
Sonerai13
Postby floridasonex » Wed Sep 17, 2014 8:23 am
Bryan Cotton wrote:Hi all,
I believe the one I got was from Great Plains. It mounts to your work table. Being
able to rotate the engine during assembly is very handy. It uses a two bold mounting
to the engine.
RT
Trigear Aerovee Sonex 1579
Flying since 4/1/13
floridasonex
Postby rizzz » Wed Sep 17, 2014 8:35 am
Here's what I used to assemble my VW:
You can find more pics on my website:
http://www.mykitlog.com/users/display_l ... 331&row=12
The brand is EMPI, I believe this is the same one GP sells but you can easily find these online on eBay or one of the VW sites.
Just google EMPI engine stand.
Postby Bryan Cotton » Sat Sep 20, 2014 1:46 pm
If I get a 2 arm VW stand, will it still work once the accessory plate is on? Are those holes the same as the case holes?
Postby Bryan Cotton » Mon Oct 03, 2016 10:35 am
I ended up buying a 4 arm HF stand. I'll use it for the Saturn rebuild later. The bolts used to join the accessory plate to the flywheel are 10mm X 1.5. Bought some from the hardware store to mount my case. Question: the helicoils in the bottom of the case seem tight and also look red. I assume this is just threadlock stuff in there and I should send those bolts home - is that right?
Postby Bryan Cotton » Mon Oct 03, 2016 3:59 pm
I had to modify my HF mount to pick up all 4 holes in the case. You can see I drilled extra holes in the top two arms.
I bought 100mm long 10mm X 1.5 bolts plus nuts and washers. I made spacers for the stand tubes to bear on. Plus by using a nut the bolt length is not critical for the blind holes.
Should work fine!
Postby mike.smith » Mon Oct 03, 2016 6:11 pm
Bryan Cotton wrote:I had to modify my HF mount to pick up all 4 holes in the case. You can see I drilled extra holes in the top two arms.
I used that same HF stand, but didn't bother with the 2nd pair of arms. I just used the top two and that was enough.
http://www.mykitlog.com/users/display_l ... 15&row=180
Postby Bryan Cotton » Sun Dec 04, 2016 6:35 pm
I implemented a few mods:
1) rivet the grip of the handle onto the tube.
2) a 1/4" PVC spacer to keep the locking pin holes aligned
3) a rubber band to retain the locking pin
4) a cleco to retain the handle
5) grease the pivot for rotating the engine
I need to replace that front caster - it is junk. Must have square balls in the swivel bearing.
Postby Corby202 » Sun Dec 04, 2016 8:06 pm
I have one identical. After building the engine for my Starlet on it I bolted a piece of 3x2 on one end, a 2' thick piece of particle board attached to those 4 lugs I had an engine stand to maneuver the engine to the front of the plane for fitting. I also modified it again with a long piece of 2" unistrut and some more wheels etc for a wing stand.
http://www.mykitlog.com/users/display_l ... 580&row=16
Phil Bird
Sonex 759 JAB 2.2 Tailwheel
Mittagong NSW Australia
Corby202
Users browsing this forum: No registered users and 47 guests
