984dm wrote:I am in no way an expert on any of this, nor do I want to imply anything negative about the plans at all, but the set of gear leg fairings I made seemed to turn out fairly nice. My plane is not flying yet, so final fitting on everything hasn't occurred, but it seems like the fairings should work just fine. All I did was buy some poster board, cut it to the rough size, then kept trimming until I got the exact shape, length, etc. that I wanted. I then transferred the poster board pattern to the aluminum. I used the plans to determine placement of the hinge halves. I also made two hinge pins for ease of installing the fairings. If you want to see pictures, please respond to my email address and I'll send some.
MichaelFarley56 wrote:
So, for anyone that's fit the gear leg fairings, did you have to trim off the ends of the fairings? Any idea how much needs to be trimmed?
Users browsing this forum: Google [Bot] and 7 guests
