Sonerai13 wrote:On the factory airplanes with our standard 54x44 Sensenich prop, we are usually seeing right around 3000 rpm static (full throttle with the tail tied down), typically see 3100 or so during an 80 mph climb, and will see around 3400 level flight at WOT (at around 2500 msl altitude).
Props can make a HUGE difference, so these numbers will probably not apply to folks using props from different sources, even if they are supposed to be the same pitch and diameter.
Users browsing this forum: Badger830 and 28 guests
