corton wrote:Hi Mike,
I just use the self-tapping screws specd by Sonex. None have come loose.
Generally, you won't see things start to loosen up until 25 hrs or so. Then you'll see temps drop. In the meantime, do the mag test. Get established straight and level; make note of your rpms and temps. Then shut off only the secondary ignition. That's the electronic ignition, not the magnetron.
If your rpms increase by 200 or so, and temps drop 30-40 deg, your secondary is too far advanced. Gotta do this in the air under flight load. On the ground they may match 100% and fool you into thinking you're good. If you see a diff, you only need to rotate the trigger magnet about 1/16" clockwise looking at back of engine.
mike.smith wrote:My 1, 2 and 4 CHTs are all doing well if I keep the RPMs at 2,700 or below, but the #3 (right rear) keeps itself from 395 to 405, with some occasional spikes to 410. Would love to fix that, and be able to run higher RPMs for longer periods of time.
19 total hours on the engine.
Users browsing this forum: Google [Bot] and 8 guests
