Cotton Waiex 191 - N191YX
Re: Cotton Waiex 191 - N191YX
Postby Bryan Cotton » Sun Aug 03, 2014 10:07 am
Hannes,
I will try the mandrel trick. I tried using a pin punch to take out the remains of the mandrel but bent it. I have drilled out a lot of solid rivets before from my previous restoration project. They are a lot easier! I have also been using vise grips to keep the rivet from spinning.
Postby Bryan Cotton » Tue Aug 05, 2014 11:36 pm
Hannes,
Thanks for the mandrel trick. It works. Had to whack a little harder than I was but was able to eject the mandrel out of the rivet. The nose ribs were still miserable because I could not hold the back side of the rivet. So, I have the skin opened back up.
I wonder if I can pop out the mandrels and drill from the back side. I don't need to get the rivets out of the hockey stick, just need to get the hockey stick off the forward spar.
Got a UPS notice that the new hockey stick is on the way. Still need to order some more angle, some more 3/4" square bar, and some more carbide drills.
Postby hsjvorster » Wed Aug 06, 2014 9:10 am
My pleasure. I am just glad I could help somebody in return. Receive so much goodwill from Sonex builders in the US in the past.
I may have neglected to mention to use a a new sharp drill bit, by now you probably gain that knowledge yourself. Difficult mandrel? That's the rule. 1 out of 10, 20. Always a difficult one.
Drilling from the back? Never tried it. I would not do it on account that the back of a rivet is not normally true to the hole. You may ruin the hole.
Thank you for the feedback. I also had to reorder some material, but had tried to avoid it on account of living in South Africa. Till that day when a pigeon had thrown my rudder from the rafters and I had to reorder a rudder. But that a a story for another day.
Regards
Hannes Vorster
#1135
hsjvorster
Postby Bryan Cotton » Fri Aug 08, 2014 9:30 pm
Riveting the fuel filler box:
Done with this page!
Postby Bryan Cotton » Sat Aug 09, 2014 11:10 pm
I have the damaged hockey stick out. I did drill a bunch of rivets from the back. I cut the tail off with a dremel cut off wheel first. I made a guard out of sheetmetal so I did not slice up the spar. Then I drilled up the rivet tail a bit, stuck a #30 bit in backwards, wiggled a bit and snapped off the tail. Leaves the spar free and undamaged.
Here is the hockey stick out, and the new one I bought from Sonex:
Postby Bryan Cotton » Sun Aug 10, 2014 11:19 pm
The road to recovery - transferring holes from the old hockey stick to the new. After drilling in the 4 corner holes, the rest of the pilot holes seem to line up but this rig makes me feel better.
I am NOT going to drill the 3/16" holes until after I bend the hockey stick.
Postby Bryan Cotton » Mon Aug 11, 2014 7:54 pm
Got all the rivet holes drilled. You have to love CNC parts. It fits.
Postby Bryan Cotton » Mon Aug 11, 2014 11:03 pm
Here we go again- the big bend.
I am not going to do this tonight. Too tired.
Postby ScottM-Sonex1629 » Wed Aug 13, 2014 9:52 pm
So, Bryan, did you guys make the big bend tonight?
(And I always thought the Big Ben(d) was some old clock tower in London)
Scott Meyer
Sonex 1629 - Sold...9/2019
ScottM-Sonex1629
Postby Bryan Cotton » Wed Aug 13, 2014 10:03 pm
Not last night-was camping with the family and in-laws up in Madison. Just got to the hangar and I am about the right amount of tired to give it a try.
Return to Photo Album
