Cotton Waiex 191 - N191YX
Re: Cotton Waiex 191 - N191YX
Postby fastj22 » Thu Jul 17, 2014 10:54 pm
Do you still need to fabricate the solid aluminum blocks for the service bulletin?
Postby Bryan Cotton » Fri Jul 18, 2014 12:08 am
John,
I have already fabricated and pilot drilled those blocks.
Postby Bryan Cotton » Tue Jul 22, 2014 10:30 pm
I am teaching Adam to be lazy. We have a bunch of 1/4" holes to drill for the southcos. Of course we go up in steps. Showed him how we change one drill size at a time then run it through each hole. Common sense of course but having it told to you and then doing it is a shortcut to the lazy way of thinking.
The next lesson in lazy is how to deburr the 1/4" holes in stainless. We used a ball stone in the dremel. Works great and is fast.
None of you guys ever answered one of my questions - is 1/4" for the southcos good or should I go to 5/16"? Replies gratefully accepted. Not too late for me to take advantage of it.
Postby Bryan Cotton » Tue Jul 22, 2014 11:07 pm
So, I am remaking the WIX-F22-06 angle. First one was the Sonex part. The holes did not line up perfectly with the verticals so I remade it. Second one did not have edge distance due to the new hockey stick bend (I think) so I made #3 with a longer flange. Found out it interfered with the WIX-F22-04 angle. Put a step in the #3 angle and didn't like it. Decided to use a shim. Made #4 using the shim to offset the holes but screwed up somehow - offset at .020 on one end, .049 at the other end for a .032 shim. I don't want to jinx myself, but #5 looks good.
Postby Bryan Cotton » Tue Jul 22, 2014 11:30 pm
Shim story:
The F22-04 angle was .032. I don't have much .032 stock. I had considered using .040 as I have a bunch of that. But in hunting around the hangar, I found the roof of the old 140 fuselage. It was the airplane Adam and Matthew both took their first rides in, when they were 5. The roof was .032. I hacked out a piece. Now every time we fly the Waiex we will be flying a part of the 140.
Lest you think I am a parts waster, I saved the roof for the window frames and stiffeners. Any restorer worth his or her salt will use a new piece of metal for the roof.
Postby Bryan Cotton » Sat Jul 26, 2014 11:53 pm
Working the tail mounting. On my next Waiex I am definitely doing this with the turtledeck off. I think Ryan tried to tell me that.
I ended up shimming the lower angle back like Ryan did.
Postby Bryan Cotton » Sun Jul 27, 2014 11:47 pm
Some backwards progress- took out the aft turtledeck bulkhead. Waiex builders, don't rivet it in until the tail is on for keeps. Impossible to clamp when it is on and impossible to tighten the nuts.
Postby Bryan Cotton » Sat Aug 02, 2014 5:28 pm
I am bummed out. Destroyed a hockey stick, angle, shim, and the .75" beef up block. This hole was #21 but is screwed up enough that I am not sure I can save it with a .25" hole.
Control-Z
I have figured out that the drill stop is a lifesaver when drilling out these infernal steel rivets.
This part is too critical to screw with.
Postby ScottM-Sonex1629 » Sat Aug 02, 2014 6:08 pm
Sorry to hear that Bryan. I too had issues with parts today and had to redrilled and remake some small angles. Hopefully you can recover from this quickly.
Scott Meyer
Sonex 1629 - Sold...9/2019
ScottM-Sonex1629
Postby hsjvorster » Sun Aug 03, 2014 8:30 am
May I help help you to drill rivets out?
Take a used mandrel and insert the mandrel into the rivet that you want to remove. From the side that you pulled and the side of the mandrel that did not broke of. Now a few light taps with a light hammer, knock the centre piece from the mandrel.
Now drill the rivet out with the same size drill that you used to updrill. Prevebly an electric drill, the rivet must not spin!
Practice first on some junk
hsjvorster
Return to Photo Album
