Got the right half of #1 in with Adam's help. Not sure how you solo builders managed that one.
Bryan Cotton Poplar Grove, IL C77 Waiex 191 N191YX Taildragger, Aerovee, acro ailerons dual sticks with sport trainer controls Prebuilt spars and machined angle kit Year 2 flying and approaching 200 hours December 23
Thanks! Due to family logistics, I am losing my co-builder until Friday after dinner. I don't want to put in the left side former #1 solo. Back to polishing ruddervators. Did any of you nutjobs polish under the hinge?
Thanks Robbie, confirms my suspicions. Darick, that is 3 ish passes of F9. I am now doing the F9 passes on the tops and then will switch to C.
I put in a couple clecoes through the plate at top and will use Bob Meyer's trick of piloting from the other side. I clecoed the plate to the forward attach angle, taped it with the good duct tape, took out the clecoes and clecoed to the spine channel to locate it. Hope it is sort of straight.
Mini rudder polished with C. I never get tired of reflection photos. Sorry!
