Scott's Sonex 1629 - N629SX
Postby ScottM-Sonex1629 » Thu May 22, 2014 11:37 pm
Some additional engine progress! Case is assembled with crank and cam shafts, and sealed up. First two sets of pistons/cylinders are measured, shimmed & RTV sealed to case. Cylinder head is sitting in position for glory sake! Still need to clean up the metal shavings and gasket up the push rod tubes and do a final install. Just doing one side of the engine at a time (unlike assembly direction instructions). I'm working with gravity and not trying to fight it!
Scott Meyer
Sonex 1629 - Sold...9/2019
ScottM-Sonex1629
Postby Bryan Cotton » Fri May 23, 2014 6:51 am
Looks good Scott. Prop may need some balance though.
Postby SonexN76ET » Fri May 23, 2014 9:25 am
I don't think you want to seal the case with RTV! Sonex is adamant that you use the designated aviation sealer in your assembly manual. I originally did my case with RTV and after hearing the disastrous results that can occur and after talking to Kerry took mine apart and used the proper sealant.
Sarasota, Florida
SonexN76ET
Postby Sonerai13 » Fri May 23, 2014 10:37 am
There are very few places on the AeroVee engine where RTV is appropriate. These are called out in the manual. Sealing case halves and cylinder bases are NOT the places where RTV should be used. PLEASE follow the manual when assembling the engine, including use of appropriate sealers in appropriate places, and you will avoid a lot of trouble.
Joe Norris
Sonex N208GD (S/N 450)
Sonerai II N13NN (S/N 1206)
Fortes Fortuna Adiuvat
Sonerai13
Postby MichaelFarley56 » Fri May 23, 2014 11:48 am
Scott can fill you in for sure, but I don't believe he used red RTV for the case halves. I think it's Permatex (Loctite) Anaerobic Gasket Flange sealant, supposedly the same stuff Rotax uses on their engines. A lot of people on the old Yahoo boards swore by this stuff and after using it myself I can say its a good product. I tried to use the Aviation Gasket sealant (#3 I believe) and that was about the most worthless product I've ever tried! It never did set up after 10 days untouched; I ended up disassembling parts, cleaning, and rebuilding after trying that stuff.
I think the only thing Scott has RTV'd is the cylinder shims.
Postby ScottM-Sonex1629 » Fri May 23, 2014 3:32 pm
Mike is correct. Anaerobic Flange gasket maker on the case halves. High temp red RTV only on the cylinder shims.
Scott Meyer
ScottM-Sonex1629
Postby SNX1508 » Sat May 24, 2014 5:19 am
Sonerai13 wrote:There are very few places on the AeroVee engine where RTV is appropriate. These are called out in the manual. Sealing case halves and cylinder bases are NOT the places where RTV should be used. PLEASE follow the manual when assembling the engine, including use of appropriate sealers in appropriate places, and you will avoid a lot of trouble.
Hi Joe,
I will begin assembling my AeroVee in the near future, so these posts on that subject caught my attention.
The AeroVee assemble manual, REV U, calls for Permatex Aviation Form-A-Gasket #3 or Flange Sealant, but other posts here say the #3 is not up to the task. Shall I follow the assembly manual and hope for the best?
Terry
Terry
Sonex #1508
N296SX
AeroVee #0736
Tail Dragger
SNX1508
Postby MichaelFarley56 » Sat May 24, 2014 10:22 am
Hi Joe,
Terry
Hi Terry,
Always follow the manual!
Mike
Postby JerryCPP » Sat May 24, 2014 1:45 pm
I assembled my AeroVee using Dirko silicone type "THE" sealant for VW and Porsch, according to my local foreign parts store. It is made in Germany, so it had to be perfect. It leaked. I took it apart and tried again, being even more careful. It leaked again. I called Kerry and asked what that blue stuff is in the assembly video. He said to use #3 Permatex. The third time, it almost doesn't leak. If anyone has a sealer that actually works, I'd like to know what it is, not just a general reference to "Flange Sealer."
JerryCPP
Postby ScottM-Sonex1629 » Sat May 24, 2014 2:14 pm
This is the product Mike used and gave me a tube of which I used on my case:
http://www.permatex.com/products-2/prod ... ker-detail
Scott Meyer
ScottM-Sonex1629
Return to Photo Album
Users browsing this forum: autopro and 17 guests
