Sonerai13 wrote:There are very few places on the AeroVee engine where RTV is appropriate. These are called out in the manual. Sealing case halves and cylinder bases are NOT the places where RTV should be used. PLEASE follow the manual when assembling the engine, including use of appropriate sealers in appropriate places, and you will avoid a lot of trouble.
SNX1508 wrote:Sonerai13 wrote:There are very few places on the AeroVee engine where RTV is appropriate. These are called out in the manual. Sealing case halves and cylinder bases are NOT the places where RTV should be used. PLEASE follow the manual when assembling the engine, including use of appropriate sealers in appropriate places, and you will avoid a lot of trouble.
Hi Joe,
I will begin assembling my AeroVee in the near future, so these posts on that subject caught my attention.
The AeroVee assemble manual, REV U, calls for Permatex Aviation Form-A-Gasket #3 or Flange Sealant, but other posts here say the #3 is not up to the task. Shall I follow the assembly manual and hope for the best?
Terry
Users browsing this forum: Google Adsense [Bot] and 24 guests
