by MichaelFarley56 » Mon May 19, 2014 3:04 pm
Unfortunately, the only way to really tell where an oil leak is coming from is to completely clean off the engine, run it for a bit, and see where the fresh oil is coming from. Eliminating all oil leaks on a VW can be done but it's a nearly impossible task sometimes! Most owners I know are comfortable with tiny amounts of oil seepage as long as there's nothing excessive. On my Waiex, I generally get a little bit of oil from around the sump cover plate that eventually ends at my cowling exit area, but it's nothing I can't comfortably live with.
Remember that the engine will use a little bit of oil in the combustion process, so it's normal to add small amounts of oil from time to time. Even healthy engines require this. Personally, I wouldn't be too concerned if you need to add a little bit every 10 hours or so.
Could you describe how much oil you saw on the Sonex you looked at? It's tough to judge quantity of oil; even a ounce of oil can look like a major leak once it's spread all around the engine compartment! Was there enough to "run" down the bottom of the fuselage?
Waiex #0056 - N569KM
Jabiru 3300A #1706
