by MichaelFarley56 » Mon Apr 28, 2014 7:40 am
Hello Captain,
I'm not quite sure how to answer this, but if the AeroVee is producing a full 80 h.p. at 3400 RPM at sea level, then yes the engine is plenty capable of producing that power. Most of us AeroVee owners won't run their engines that hard for prolonged cruise operations, but generally speaking the engine will do just fine. On my engine, it will happily run anywhere from 3000-3300 RPM for prolonged durations. Last fall, when I was chasing Mark Waldron down to Crossville, I don't think my RPM was below 3300 for over 2 hours!
Remember though, as we climb in altitude and the air density decreases, power output on the engine will also decrease, so even if you're turning a full 3400 RPM at high altitudes, you won't be producing the full 80 h.p.
As for your next question, I can tell you that, on my airplane, full throttle RPM in level flight will produce RPMs of close to 3450-3500 RPM. Slightly over redline but I'm okay running that RPM for a few minutes to test things. It's important to remember though that the airplane itself can have a major effect on the engine readings. If the Sonex is built straight, light, and has all fairings installed, it will go faster and as a result the engine will turn higher RPMs. On the other hand, you may have a perfectly healthy engine that can't turn full RPMs because the wheel and gear leg fairings aren't installed, the airplane is heavy, etc.
Does this help answer any of your questions?
Waiex #0056 - N569KM
Jabiru 3300A #1706
