Stock tailwheel pushrod
Postby gammaxy » Sun Feb 09, 2014 6:58 pm
Does anyone use the stock tailwheel pushrod? I went to install it today and it seems like it will require significant bending to fit correctly, but even then it seems like it will most likely wallow out any holes in aluminum any time the tailspring flexes.
I see a lot of people using ball joints and will likely do the same.
Re: Stock tailwheel pushrod
Postby MichaelFarley56 » Sun Feb 09, 2014 9:18 pm
Hi Chris,
I used the stock piece for around 50 hours, but when I noticed one of the bolt holes start to elongate I decided that was a good time to make my own adjustable pushrod. I took some 4130 steel tube, bent it as needed, and had two rod ends welded to it. The new piece seems like a much longer lasting option, plus it's nice to have an adjustable length piece. It's only fair to say though, that the original piece worked just fine in terms of fit and finish.
Best of luck if you make our own piece.
Waiex #0056 - N569KM
Jabiru 3300A #1706
Postby N111YX » Sun Feb 09, 2014 10:09 pm
Please note that welding is not required for such a modification. Look closely and you'll see steel roll pins that I have used with great success... :)
Kip
Jabiru 3300 #1637 and #3035
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1100 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Postby Fastcapy » Sun Feb 09, 2014 10:32 pm
Mike Beck
Oshkosh, WI (KOSH)
Sonex #1145 N920MB
Fastcapy
Postby gammaxy » Mon Feb 10, 2014 10:23 am
Thanks guys. I like the suggestions on how to do this without welding.
I measured my stock pushrod and compared it to the plans. It is about 1/4" too "tall" to connect to the tailwheel horn when attached at the rudder plate. This seemed significant, but I bet if I bent one of the tabs a degree or so it would fit.
Postby wlarson861 » Sun Mar 30, 2014 12:50 am
I used a hardware store piece of 3/16 inch rod and threaded it for a 10/32 rod end bearing and stop nut on both ends. I bent the rod to align with the flats. I used the same rod with the original welded tail wheel and the new one.
Bill Larson
N861SX
wlarson861
Postby Sonex541 » Mon Apr 07, 2014 9:44 pm
I bought a solid piece of aluminum rod and drilled and tapped both ends and bought , 2 heim joints and lock nuts , I went with a larger diameter than needed but it worked out great , that and the larger vans tail wheel , and kip bracket it's been working great ,
Sonex541
Postby vicdelgado9 » Thu Apr 10, 2014 11:12 am
Nice info, I love to see all of the ingenuity builders come up with! I was going to make the rod end bearing push rod to start off with, but have made so many changes already and it bogging me down, I have now decided to stick to plans as much a possible to finish my build, and then I can alwasy upgrade after I am flying. So I just made the stock push rod for now while I was welding already.
Vic Delgado
Sonex "CorVex" #969 Plans
3.0L Corvair, tail dragger, single stick
Houston, TX
Expercraft Builders Log
complete: tail,wings, welded & angle parts
"Old Corvairs never die, They just earn their wings".
vicdelgado9
Postby sonex892 » Thu Apr 10, 2014 5:04 pm
As much I initially disliked the crude stock tailwheel push rod is it does work. The tab on one end needed adjustment to correct the angle. I can weld so I just re welded it. I probably could have gotten away with just bending the tab.
I have almost 500 landings on my plane now and this crude arrangement is doing fine. I'm guessing its also lighter than using rod ends.
Steve 892
sonex892
Postby hickej » Fri Apr 11, 2014 12:52 am
I've had no issues with the stock tailwheel push rod. I tightened it once during the first 40 hours and check it every pre-flight. It is holding up just fine at 135 hours.
-Jim Hicke W0162 3300
hickej
Users browsing this forum: WolverineYX and 79 guests
