Rynoth wrote:Hi Scott, looks good! I see that you already drilled your upper splice plates up to size... I'm just going to reiterate here what I've said in Bryan Cotton's build, to watch for the 40" width of the fuselage, since the laser cut parts don't exactly result in the 40" width you (I) think it should, unless you trim a bit from the cross tie box.
Your pictures look great! Do you have a blog/website of your progress other than this forum? I would love to keep up with your build!
Hey Ryan:
Thanks to your prior post, I did pre- measure the width at the upper area of the fuselage where the box beam goes, and I trimmed about 1/16" of material off both sides of the assembly. Without doing this I could not get the cross piece to fit in with the splice plates. With this updrilled to final size, I am right at 40" of width.
I have a simple Expercraft web-site that I keep for future FAA airworthiness inspection. I started posting to this forum with updates with milestones. Thanks for your kind words.
Mike - I wish I needed more help. This project for the most part is pretty easy to do by yourself. I can't even convince my son to help anymore...so I've learned how to do most tasks solo.
