by mike.smith » Fri Nov 29, 2024 8:12 pm
What are the CHTs? That's what counts. EGTs are good for seeing trends, but not really much else. If the EGTs are 2,000 deg and the EGTs are within limits, then that's what is meaningful. One or two hundred degrees difference on EGTs on a VW is perfectly fine. It's not a fuel injected engine, and will NEVER have matching EGTs. Never. If the CHTs are good, and you are getting full power, you are good to go.
Also, you did not note if this was an engine that is still being broken in, or if it has a bunch of hours on it already. If it's still being broken in, then it really is all about the CHTs staying within limits, and that takes time, and climb management.
More info on your CHT/EGT numbers would be helpful.
