Ball type slip/skid indicator
Re: Ball type slip/skid indicator
Postby pfhoeycfi » Sun Nov 10, 2024 9:36 am
Lev o gage 4 works great. Yaw string works pretty good as well but the deflection isn't as pronounced as on a glider. I'm gonna relocate it a little further back on the canopy. I had it just aft of the front bow.
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
pfhoeycfi
Postby Skippydiesel » Wed Nov 13, 2024 2:48 am
I apologise , in advance, however my scepticism has the better of me;
How on earth can a "yaw string" or "tuft of wool" etc give any meaningful information, when used on an aircraft with an operating, front mounted engine/propeller ???
The whole concept of the tuft, is that it indicates relative wind/air movement, over the cockpit, to the pilot, so that he/she can determine balanced flight.
With a front mounted engine, all the tuft will tell you is that its being affected by prop blast - the exception may be when the aircraft is in a strong side slip.
Skippydiesel
Postby GordonTurner » Wed Nov 13, 2024 9:36 am
Why don’t you try it before you wade in with your opinion.
