daleandee wrote:We also used screws instead of rivets on the sides to fasten the canopy.
Tony4aro wrote:Bryan: Thanks for the tip on the slot. I'm still trying to figure out what I want to do with that. I just simply don't like that little slot and tab. I'm half tempted to put in a locking hatch door on the side of the plane so I can just reach in and unlatch it. But I guess I need to figure that one out quick. Do you have any thoughts on the "Factory" opening tab?
Tony4aro wrote:Karmarepair: I'm way ahead of you. Was already planning screws. 1) It just doesn't make sense to use rivets. That would be a total pain when a replacement is needed. and 2) I've worked with plexi in the past (small personal projects) and any time pressure is held on it... it will crack. The first small box I made had screws. Looked nice. BUT... the next morning, all the screw holes were blown out. (They were small metal screws)
karmarepair wrote:I think aluminum rivets with aluminum shanks with the holes in the canopy oversized would be fine..
