by MichaelFarley56 » Thu Mar 13, 2014 7:23 am
My starting procedure is the exact same as Mike's, except that when I push the mixture in to FULL RICH, I need to pause around 2 seconds in order to prime my engine. Just like Mike said, once the fuel valve is open, throttle cracked, and mixture pushed in, fuel will start to flow through the AeroInjector but for me, a very slight delay (no more than 3 seconds) works as a prime for the engine.
Also, once the engine starts, I will also lean the mixture on the ground for idle power and engine smoothness.
Waiex #0056 - N569KM
Jabiru 3300A #1706
