Higher gross weight limit for Sonex & Waiex
Postby wannabeYXbuilder » Fri Oct 18, 2024 12:06 am
I’ve been a long time reader on the forum but this is my first post. I’m curious what the Sonex community reaction is to the recent announcement from Sonex of the increase to 1220lbs gross weight for any A or B model Sonex or Waiex with at least 100hp. There’s a nice interview on the Experimental Aircraft Channel, https://youtu.be/oeEAIp_Otvw?si=Tn_ZTFYvjzOvK1oT
wannabeYXbuilder
Re: Higher gross weight limit for Sonex & Waiex
Postby Bryan Cotton » Fri Oct 18, 2024 9:35 am
Welcome to the forum! There has been some discussion already. What's not to like? I do believe it is better to use the gross weight increase for carrying fuel, bags, and people rather than porking out the empty weight. Light aircraft perform better in general.
Postby wannabeYXbuilder » Fri Oct 18, 2024 8:11 pm
As my handle implies I have not yet started building anything except in my head. I have been thinking of targeting a 650lb empty weight but even with that you would have a hard time filling both seats, full fuel and baggage unless you had two very light occupants, under the original gross weight. Are there other threads on the topic on the forum?
wannabeYXbuilder
Postby Bryan Cotton » Fri Oct 18, 2024 8:52 pm
To get the gross weight increase, you need 100+ HP. At 650 lbs empty weight your useful load would be very good by Sonex standards. What engine do you like?
Postby wannabeYXbuilder » Sat Oct 19, 2024 9:17 am
I like the UL Power 350 for the power, fuel injection (no carb icing), FADEC control (single lever operation) and relatively low weight. An alternative would be the latest version of the Jabiru 3300 (Gen IV I think) which seems to have most of the bugs worked out compared to the early versions.
wannabeYXbuilder
Postby Dave Wolfe » Sat Oct 19, 2024 10:35 am
Whats your mission (edit:) for the airplane?
Dave Wolfe
Postby wannabeYXbuilder » Sun Oct 20, 2024 8:48 pm
As far as what I would intend on using the plane for it would be for day, VFR only, local $100 burgers, weekend trips to the beach, local fly-ins, occasional cross country. I would like to build a safe, low cost, light weight, efficient plane with some basic creature comforts.
wannabeYXbuilder
Postby Dave Wolfe » Sun Oct 20, 2024 11:08 pm
The sonex checks most of those boxes.
The big engines made me think fast cross country are your main goal. The light wing loading and small tank limit its cross country capability somewhat unless you are trying to stay within the light sport pilot limitations.
Dave Wolfe
Postby Skippydiesel » Mon Oct 21, 2024 3:06 am
"The light wing loading and small tank limit its cross country capability somewhat unless you are trying to stay within the light sport pilot limitations."
Or fit extra capacity for extended duration.
Skippydiesel
Postby Skippydiesel » Mon Oct 21, 2024 3:07 am
Skippydiesel
Users browsing this forum: Google [Bot] and 26 guests
