Bryan Cotton wrote:karmarepair wrote:After dropping the plate, replacing the screen, installing "lifetime" silicone gaskets with a light smear of permatex #2, and installing the acorn nuts on the sump plate studs with NEW copper washers (new copper crush washer on the VDO drain plug sensor too) with a generous smear of Permatex #2, and carefully tightened them up using a star pattern and little nibbles of torque (they were barely finger tight when removed): no more drips.
Mine always loosened up a bit. I drilled for safety wire.
Users browsing this forum: No registered users and 20 guests
