by Skippydiesel » Tue Sep 10, 2024 9:44 pm
Multiple, in line filters, should be avoided.
Simple physics - every filter on a line/pipe presents as a restriction/resistance to fuel flow.
The ideal would no filters at all. This is impractical - with the best will/care, some contamination will always occur (hopefully a filter will prevent its entry to the metering system)
Every filter, constriction and curve, in the fuel reticulation system, causes a reduction in flow.
The more restriction, the harder downstream pump(s) will have to work to deliver the fuel, to the metering system.
Passing fuel through consecutive, in line filtration, is not only unnecessary, it goes against the principles of filtration (more is not necessarily better), hydraulics, minimising complexity and weight.
Rotax fuel filtration standard is 70-100 micron - this can easily be achieved by passing the fuel through one appropriately sized filter. If you are concerned about filter blockage (& you should be) choose a filter with a large surface area (usually a bigger filter) that can accommodate more contamination before blockage occurs.
Having all your fuel go through one filter introduces a potential failure (critical) point. Should that filter block in part or whole, so the engine will be starved of fuel.
The best systems, have supply redundancy ie two supply lines, both with appropriate filters.
Small (often Rotax powered) aircraft can achieve this level of redundancy by having two separate supply systems (preferably from diffrent tanks or at least 2 pick up points). Efficient, light weight, leak proof, low cost screen, in line, filters can be installed on both lines.
