by funflyingguy » Mon Aug 26, 2024 9:54 am
so.... yesterday, i bit the bullet and replaced the top magnetron on my aerovee engine. it it working normally again, including the mag check. all the suggestions here helped alot. still, it seems that these should be a bit easier to service. first, 7/32" is an odd size requiring a really tiny, uncommon wrench to remove. i thought about a larger bolt, a 1/4" nut and boring the accessory plate out to that size, but left that for the next time. also, the spark plug leads are so much in the way of the left side nut on the magnetron, that i ended up tying a small weight to them to pull them over to the right side of the engine for more opening. it was barely enough. still, a good experience to have done it. i never got to do anything that involved on my piper cherokee!
so a question....... i realize the safety factor of have a magneto/magnetron setup. but does anyone know of a reasonable replacement (cost and maintenance) for the magnetron setup?
.... jim / funflyingguy
3rd owner of sonex #1010 - N485PB
2017 can-am spyder F3T
2013 suzuki vstrom 650
2022 forest river popup camper
concord township, ohio
over 36 years flying
