Do I have a big problem here?
Re: Do I have a big problem here?
Postby DWest » Thu Aug 15, 2024 11:44 am
Interesting where this experimental build brings me. Did some research on 6061 t0-6 ductility and understanding of the process. Perhaps a heat gun and a cold wet rag might help? I don’t know what else to do at this point other than abandon it and get a new skin but then hopefully my holes will line up if not then, I’m in even more of a mess!
How ‘structural’ are we talking here? I mean we’re putting holes in the leading edge for pitot tubes and landing lights. Perhaps that’s my next topic of research, aeronautical structural design!
DWest
Postby Area 51% » Thu Aug 15, 2024 12:58 pm
DWest wrote: I don’t know what else to do at this point other than abandon it and get a new skin but then hopefully my holes will line up if not then, I’m in even more of a mess!
I had a leading-edge skin that was de-burred, dimpled, and ready to rivet. It got badly bent by a visitor that couldn't keep control of his feet and it couldn't be saved. I got a replacement with the same worries as you. All the holes lined up with the dimples falling into place perfectly.
CNC machines to the rescue.
Postby DCASonex » Fri Aug 16, 2024 8:22 am
The wing skins are VERY DEFINITELY structure. do not even think about using high heat on them.
Postby DWest » Fri Aug 16, 2024 3:00 pm
Thanks for all the insight everyone! I’m going to stick with rule #2 of my guiding principles of don’t cut corners/do it right. New skin on order.
I guess I will start making flaps and ailerons while I wait.
DWest
Return to Sonex-B / Waiex-B
Users browsing this forum: Google [Bot] and 10 guests
