Bryan, I just want to go ahead and (redundantly) reiterate that the cross tie box assembly (WIX-F24) will end up needing some slight trimming of the laser cut parts to clear the upper splice plate when you're assembling the aft fuselage box assembly (WIX-F21).
Tonight I drilled out my cross tie box and turtledeck former #1 in order to replace the bad splice plates that were shipped in my kit. I thought I would have an easy time of correcting the fact that I did NOT trim the cross tie box and had slightly greater than 40" (about 40 1/8", but you can tell it's not right) outside diameter of the fuselage. I don't think it's going to be that easy however, and I'll probably need to order new cross tie box parts and replace it altogether, due to the bolt and rivet holes already drilled through them.
I've found several builder logs who ran into this issue of an oversized laser-cut part (actually, it's exactly as called for in the plans) and (thankfully for them!) caught it and corrected it. Here's an example of what I'm talking about.
http://www.kansasflying.com/sonex1017/f ... 80829.htmlThis is the most "gotcha!" thing I've run into so far in my build, and unfortunately it got me. Can't recall any other laser-cut part yet that had to be modified in such a manner not called for in the plans. Maybe I'm the first one to ever miss it.
