Cotton AeroVee 0795
Re: Cotton AeroVee 0795
Postby Bryan Cotton » Sun Aug 04, 2024 11:48 am
Postby Area 51% » Sun Aug 04, 2024 11:51 am
Yep..........just like that.
Postby Bryan Cotton » Mon Aug 05, 2024 10:20 pm
Postby Bryan Cotton » Fri Aug 09, 2024 11:03 pm
Postby bvolcko38 » Sat Aug 10, 2024 9:12 am
Are those your intake manifolds? Did you modify them with that notch?
Bill Volcko XNS0068
Aerovee and Prince P-Tip
V6
First hole 4/1/16
First flight 8/24/18
Phase I complete...finally!!!
bvolcko38
Postby Bryan Cotton » Sat Aug 10, 2024 9:30 am
bvolcko38 wrote:Are those your intake manifolds? Did you modify them with that notch?
Yes to both
Postby Bryan Cotton » Sat Aug 24, 2024 12:16 am
Heads back on:
Postby Bryan Cotton » Sun Aug 25, 2024 6:48 pm
My new heads had smaller intake ports than the old ones. Look at that sharp corner.
I rotated the engine until the intakes were closed, jammed the ports full of paper towels and blue tape, then went at it with the Dremel and file.
Postby Bryan Cotton » Sun Aug 25, 2024 6:53 pm
The intake tube did not line up with the GPAS manifolds. Not that they lined up great with the stock manifolds but it was unworkable. So I cut an inch out of both sides, down low.
hacked intake tube.png (1.11 MiB) Viewed 846 times
Now I have more degrees of freedom:
intake tube flex sections.png (1.12 MiB) Viewed 846 times
Next up: modify the baffles for the new intake location.
Postby Bryan Cotton » Mon Aug 26, 2024 11:55 pm
Here is the difference in manifolds as shown on the baffle:
Hacked out:
I made a ring. 1.5" holesaw for the ID, 2.5" holesaw for the OD.
Once the silicone adapter slides down, the inside of the ring is sealed and the outside seals the oblong hole in the baffle.
Next up: extra credit baffle tweaks. I want to really go after good cooling.
