Cotton AeroVee 0795
Re: Cotton AeroVee 0795
Postby Area 51% » Sun Jun 30, 2024 2:12 pm
Try this.....You don't need to have the crank installed in the case to set the end play. It's easier to assemble the crank, bearing, shims, and flywheel on the bench and check the clearance with a feeler gauge there.
Did you remove the temper in the pushrod by heating it up to install the ends?
Area 51%
Postby Bryan Cotton » Sun Jun 30, 2024 2:18 pm
Area 51% wrote:Try this.....You don't need to have the crank installed in the case to set the end play. It's easier to assemble the crank, bearing, shims, and flywheel on the bench and check the clearance with a feeler gauge there.
I set it to .005 last night. We did not heat our pushrods for installation. A local VW guy seems to think we should have.
Postby Bryan Cotton » Sun Jun 30, 2024 10:53 pm
Here is that bad pushrod:
Postby Bryan Cotton » Sun Jul 14, 2024 9:18 pm
One of the things I'd like to figure out is why I can't get our cruise oil pressure below 60 psi. So I've decided to pull the galley plugs and have a good look.
galley plugs out.png (1.11 MiB) Viewed 1382 times
galley plugs front.png (1.05 MiB) Viewed 1382 times
I used this as a guide:
https://www.huelsmann.us/bugman/FilterTech.html
Sonex tech support said I shouldn't pull the plugs. But I did anyway. Also I used this slide hammer from HF:
https://www.harborfreight.com/slide-ham ... 56894.html
Worked great!
One interesting thing was the small plug on the front of the engine, where the oil pump out galley intersects the front bearing galley, had a pipe thread tap instead of a plug. I had to put some heat on the case to get it out. It was brass I think.
Postby kmacht » Mon Jul 15, 2024 12:16 am
I pulled the galley plugs on my case when I rebuilt the motor. There was actually quite a bit of metal shaving debris in there. I’m not sure it affected anything as the debris was packed at the ends where it wasn’t restricting flow but cleaning it all out provided some peace of mind.
#554
kmacht
Postby Area 51% » Mon Jul 15, 2024 9:59 am
Behind that pipe plug, there used to be a restrictor as delivered from VW. It's typically removed to enhance the oil flow to the front bearing.
That's right..........I never throw anything away.
Area 51%
Postby Bryan Cotton » Mon Jul 15, 2024 7:41 pm
So - I should remove it? I haven't checked if my case has it yet.
Postby Area 51% » Tue Jul 16, 2024 6:48 am
If you have a pipe plug, the restrictor has more than likely already been taken out.
The stock blocks have a pressed-in plug in that location.
Area 51%
Postby Area 51% » Tue Jul 16, 2024 6:53 am
Another thing, The Aerovee assembly manual used to call for enlarging the oil supply hole in the nose bearing. Probably still does. When I pointed out to Sonex back in 2017 that my pre-assembled crank did not have the larger oil hole in the bearing, they said they discontinued that practice.
I removed the bearing and up-drilled the hole.
Area 51%
Postby Bryan Cotton » Fri Jul 19, 2024 9:51 am
My restrictor was out.
For those who are able to do the full flow mod without disassembling the case, I'm not worthy. There was no scary debris in the galleys before but there is now!
For now I'm just going to plug the holes. 3 down, 6 to go.
