BRS wrote:I have MATCO wheels/brakes as well. I went with the smaller tubing. It is rated at a higher pressure, does not seem to restrict flow or brake response at all, is a bit more flexible. My gut feeling is that it's also easier to bleed.
I also have MATCO hand brake which I have always felt like it wouldn't bleed (trapped air) due to the bleeder location on the side not the top. I just recieved in the mail another brake handle from BlackMax which I'm going to give a try.
Rofomoto wrote:BRS wrote:I have MATCO wheels/brakes as we...I'm going to give a try.
Sounds like I have the same set up … matco hand brake… Did you get the line from Matco also? … it states it’s nylon …
Users browsing this forum: Google [Bot] and 3 guests
