Firewall Forward Layout
Discussions for ULPower engines.
Postby tmritter44 » Sun Jun 30, 2024 8:14 pm
Battery, fuel pumps and other items for UL350i located on Sonex-B firewall with good results thus far, including ECU located on aft side. Find pictures with general layout and progress to date under "Members Projects" on our EAA chapter website at: eaa1683.org
tmritter44
Re: Firewall Forward Layout
Postby WesRagle » Mon Jul 01, 2024 2:09 am
HI tmritter44,
Very nice!
I usually find a way to make at least one mistake laying out the firewall. On the Onex, I decided to test the layout on some Home Depot lexan, and install it on the plane, so I could ensure I didn't interfere with any of the structure on the cockpit side. Then I used the lexan as a template to transfer the hole pattern onto the actual firewall.
Good Luck,
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Return to ULPower
