Time for an update.
I decided to keep things simple and I abandoned the constant speed propeller. A ground adjustable would probably be a decent choice, but I just don't like them. I am likely going to order a fixed pitch prop from Catto. I have been working back and forth with Catto and hope to have something finalized and in production soon.
Also in the name of simplicity I abandoned the auxiliary fuel tank. I installed the new fuel tank straps that were part of the service bulletin and I am working on a shutoff valve that I can access from the seat in my harness. The fuel pump and filter assembly is ready to install, once that goes in I can make fuel lines and the fuel system will be done.
I started mounting instruments in the panel and started laying out my electrical system.
I installed the control sticks. I flew a plane recently that utilized quality bicycle grips on the control stick. I love them!....and I had to have some. I like a standard round handle with one button on top. The fighter grips, and contoured grips just aren't for me. There are some nice foam ones and a few rubber ones for 1-inch tubing, but the options are limited and and not nearly as comfortable to me. Problem with the /bicycle grips is they are made for 7/8 diameter tube. I cut the old ones down, made a jig, and welded a piece of 7/8 tube on to the factory units. I left them long for now and I will trim them later when I get a better feel for where I want them. I love the feel of these grips. I have PTT buttons for the top center.
![IMG_1513.jpg (3.06 MiB) Viewed 278 times IMG_1513.jpg](./download/file.php?id=5504&t=1&sid=9627f40291b8b39e63507807dc1a9d22)
![IMG_1514.jpg (2.49 MiB) Viewed 278 times IMG_1514.jpg](./download/file.php?id=5505&t=1&sid=9627f40291b8b39e63507807dc1a9d22)
I also have the throttle cable and attachment brackets fabricated and mocked up. This engine has a sensitive throttle and I wanted precise control during cruise, so I opted for a macfarlane vernier throttle. The other issue was the throttle body was spring closed....and it was 2 strong springs. I guess Yamaha didn't want the snowmobiles taking off at full throttle in the event of a failure for some reason ;). I removed the springs and the the throttle body has no resistance to movement at all. I think the intake vacuum would still close it if the throttle cable falls off, but I think the chance of that happening are very unlikely when there is almost no force on the connection. I thought about adding springs to open, but I don't think it is worth it as I believe it would increase my chances of causing binding and or some other issue. I am comfortable with what I have. This conversion also required that I move the cable to the opposite side of the throttle body and increase the travel distance at the throttle body (the increased travel distance helps with the sensitivity issue too). There is a bracket off the starter to hold the cable at the fixed side and a bracket off the cam to provide a lever for attachment. The throttle is smooth as silk and works beautifully.
![IMG_1580 (1).jpg (3.43 MiB) Viewed 278 times IMG_1580 (1).jpg](./download/file.php?id=5506&t=1&sid=9627f40291b8b39e63507807dc1a9d22)
![IMG_1581.jpg (3.12 MiB) Viewed 278 times IMG_1581.jpg](./download/file.php?id=5507&t=1&sid=9627f40291b8b39e63507807dc1a9d22)
