by Bryan Cotton » Tue Jun 25, 2024 2:43 pm
Rev 2 of the mount:
![Screenshot_20240623-230719.png](./download/file.php?id=5497&sid=b5cbb3710052b72bafc8a12d85210b4b)
- Screenshot_20240623-230719.png (956.75 KiB) Viewed 473 times
Rev 2 may not be totally accurate. But next I glued it on with 5 minute epoxy. Once it seemed strong enough I did a trial fit.
![beacon trial fit.png](./download/file.php?id=5498&sid=b5cbb3710052b72bafc8a12d85210b4b)
- beacon trial fit.png (931.05 KiB) Viewed 473 times
I cut the heads off some long #8 screws and sharpened them. Then I screwed them in, with some WD40 on the threads. Put a piece of heat shrink tubing over it and then glassed over with 4 or 5 layers of thin glass. Before I put resin to it, I cut up to the edge of the mount around the perimiter of the part so the cloth would lay flat around the corner.
