Cotton Waiex 191 - N191YX
Re: Cotton Waiex 191 - N191YX
Postby Bryan Cotton » Sun Jun 16, 2024 5:11 pm
See picture:
It looks like the #3 exhaust valve has deformed. Seat is not flat - more concave. Also there were burrs at the top of every valve. Had to file the keeper groove edges to remove a burr so I could get them out.
Edit: I accidentally marked 3E as 1E.
Postby Bryan Cotton » Mon Jun 17, 2024 11:36 pm
Ok, done screwing around. New heads on order.
We are taking the opportunity to replace the rear main corrosion prevention system. Also plan to split the case and see if we can find the reason why we can't get cruise oil pressure below 60+ psi.
Piston, rings, and cylinders look good.
Postby Hambone » Wed Jun 19, 2024 3:31 pm
Following!
Hambone
Postby pappas » Wed Jun 19, 2024 5:34 pm
Make sure that you get a 3-angle valve grind. After I replaced the heads and did the 3-angle, my turbo ran like it had never before. The valve grind made a huge difference. Much more compression.
Sadly, it was a broken #4 exhaust valve adjuster foot that did in my most recent Waiex. But after the new heads and valve job, that thing was running AWESOME until the adjuster failed and put me in the desert, totaling the plane. If not for that, I would still be flying the Waiex and would be very happy with the performance and cost of ownership. Love the newly completed RV7-A, but it is much more expensive to play with!
Lou Pappas
Phoenix, AZ
RV-7A Flying (2024)
Waiex B Turbo (2016)
RV-8 (2009)
Waiex Legacy 3300 (2007)
Hiperlight SNS-9 (1991)
Falcon Ultralight (1989)
pappas
Postby Bryan Cotton » Wed Jun 19, 2024 6:09 pm
pappas wrote:Make sure that you get a 3-angle valve grind.
Lou,
Did you use a local shop or send your heads out?
Postby Area 51% » Wed Jun 19, 2024 8:03 pm
Fact is.... most VW heads already come with the 3 angle valve job. Some offer 4 or 5. In the performance world, the closer you can get to a radius at the seat, the better the air will flow. But, as a previous poster pointed out, the seat to valve margin suffers.
This picture is from a 1977 repair manual.
Area 51%
Postby pappas » Thu Jun 20, 2024 5:00 pm
I have a friend with a custom Harley shop but he also built VW's for decades. He did it in his machine shop. I think any machine shop can do these. Yes, there are 4 and 5-angle jobs too. The price shouldn't be more than a couple of hundred, I don't think. The difference for me with the new heads and precision 3-angle was so much better than stock.
Lou Pappas
Phoenix, AZ
RV-7A Flying (2024)
RV-8 (2009)
pappas
Postby Bryan Cotton » Sat Jun 22, 2024 5:18 pm
Postby Bryan Cotton » Sat Jun 22, 2024 6:50 pm
My #3 intake seat fell out.
Postby Bryan Cotton » Tue Aug 13, 2024 2:47 pm
Motor is back on. Per Sonex, my new heads are headed for the machine shop this week.
Return to Photo Album
