Hi All,
I’m happy to say my wing rigging issues are resolved, it set me back about a month but what’s that in the grand scheme of things anyway.
Here’s how things went this weekend.
As mentioned before I'm first trying to copy the existing (enlarged) holes to the first set of the new attach angles so that I don't have to do the scary drilling with the wings installed on the fuselage anymore.
If it doesn't work I have a second set of attach angles with no holes pre-drilled to do it the classic way.
The holes in the old angles were only slightly enlarged, too small to make any sort of bushing from tubes or whatever so I made a bushing from a coke can, cutting it into small strips and rolling one into the enlarged hole. This worked perfectly, I was able to drill a new hole precisely centred in the old enlarged hole.
![Image](http://www.kitlog.com/photos/project_1898/full/FP02032014A000XC.jpg)
![Image](http://www.kitlog.com/photos/project_1898/full/FP02032014A000XD.jpg)
Before I put my wings back onto the fuselage, first I needed to check the spars actually still mate correctly. Remember I took the angles off the spars, attached new blocks and drilled those on the drill press, in theory everything should still be in line but you never know, better to check this before installing them into the fuselage.
As expected, everything is still in line, the pins need to be tapped in/out with a hammer but that is how it should be. Perfect, so far so good!
![Image](http://www.kitlog.com/photos/project_1898/full/FP02032014A000XH.jpg)
![Image](http://www.kitlog.com/photos/project_1898/full/FP02032014A000XI.jpg)
![Image](http://www.kitlog.com/photos/project_1898/full/FP02032014A000XJ.jpg)
After checking the spars still mate ok, it was time to re-install the wings and hope my experiment with the first set of attach angles so I won't have to do any more drilling.
I had my friend Austin come over to give me a hand installing them again.
And guess what, they fit perfectly, I could not be more pleased with the result, I must say I expected to have to need at least one of the extra angles I made but no, everything matches and lines up.
The pins fit, very, very snug into the holes, a really good result indeed, again I am very happy. I can sleep again! (I've lost quite a bit of sleep over this issue).
After we were done I put the wings in the new stand I made yesterday, looks good and works well.
![Image](http://www.kitlog.com/photos/project_1898/full/FP02032014A000XK.jpg)
![Image](http://www.kitlog.com/photos/project_1898/full/FP02032014A000XL.jpg)
![Image](http://www.kitlog.com/photos/project_1898/full/FP02032014A000XM.jpg)
Also, if you’re wondering about the hitch pins I’m using instead of the AN6 bolts they are a set of 3/8" x 4" hitch pins from McMaster, part number 98497A595. I believe these are the ones Sonex use in their aircraft. When I was talking to Kerry about my rigging issues he said he also had hitch pins in his aircraft. Because they have a tapered tip they are much easier to install than the bolts. They are grade 5 steel (imperial) so should be more than strong enough.
![Image](http://www.kitlog.com/photos/project_1898/full/FP02032014A000XE.jpg)
Now, I can finally move on to my panel, wiring and soon after the engine installation.
