WesRagle wrote:Hi Brock,BRS wrote:Yup! Revmaster vs Aerovee design choices. I'll probably not take the time but it would be interesting to mount a temporary probe like in the aerovee instructions just to see how different the two locations are.
I know it's a big ask, but if you get a chance please do. It would be valuable information.
Also, you wouldn't happen to have a pic of the thermocouple tip. Just wondering how the junction is made. Cr/Al or Copper Con?
Edit: What is that black adhesive used to secure the T/C wires?
Wes
So the joke was to mount the probes where they made you feel the best and just go fly the thing! 8~)
BRS wrote:Wes, the RTV (my favorite) I buy at Napa (National Aircraft Parts Association). The junction looks to be a simple weld. I believe this kind of probe can be twisted and crimped. I'll see about doing a ground run comparason test.
Edit:
Wes
bvolcko38 wrote:In my experience, the Aerovee valves do not rotate at all. Even though my rockers were set up as per the plans, I see absolutely no evidence of valve rotation. I've had both heads off at different times and there is no exhaust valve rotation whatsoever. There is no way the lubed rocker with an arm of a couple millimeters can overcome the friction of the valve spring. Certified, and other engines have valve rotators.
Kai wrote:Why would it be different on Aerovee? Perhaps different production setups in Mexico?
