Bryan Cotton wrote:No photos. I was going to do my flight review in the Waiex today. Did the ground portion and then on startup the airplane ran like crap. Right aft EGT was low. So I have some troubleshooting to do. The good news is it seems to be a hard failure and I know what cylinder. The last few flights we had a slight miss in some conditions, like climb on the primary only. But we could only feel it, not really see it on the gauges. It did smooth out above 1400 RPM today but that's not good enough.
Was going to switch to the C140 but the winds came up over the flight school limits for the airplane.
Area 51% wrote:If the seat were receding, I would think the adjustment would get tighter and not looser. And a "tight" valve is an unhappy valve. .
Kai wrote:Interesting
Are you sure an overheated valve stem has not increased a few fractions in length? We´ll see!
Bryan Cotton wrote:The adjusting screw is turned all the way out. The valve to rocker clearance is tighter. In the current state I need a shorter pushrod.
