Kai wrote:Wes,
Well, yes- should you decide to go for an efi system with en ecu having sequential control og each injector, balancing the egt´s should be well within reach. However, each cylinder producing the same power is another matter altogether. ...
Kai wrote:Anybody with excess of say at least 500 issue free hours in the air please tell us about your findings and solutions!
Bryan Cotton wrote:I'll suggest this thread as a good place to do it:
http://www.sonexbuilders.net/viewtopic.php?f=7&t=7279
However, I did not want to be a naysayer and squash all his ambitions.
Here's a link to the first: https://www.abbottaerospace.com/downloa%20...%20rmocouple/
Pressure differential between the upper and lower plenum should be about 9 inches of water at full power, which a well designed and implemented "firewall" forward should be able to easily achieve at about 100 MPH.
WesRagle wrote:Where is the link to the second :-)
WesRagle wrote:That pretty much proves that VW flyers don't need to look at CHTs when they find burnt valves. The problem is more likely high valve temperature and the best proxy we have for that is EGT.
Jester504 wrote:Generally, I agree, but it's important to point out that while the valve temperature correlates with EGT, the absolute EGT measurement itself isn't really precise, so it still doesn't tell us directly or indirectly what temperature the valve actually is.
Users browsing this forum: Kai and 27 guests
