ANR Headset Recommendations
Postby mike.smith » Mon Jun 10, 2024 7:41 pm
I'm looking to replace my old passenger headset with a new one that has ANR. Any recommendations that won't break the bank? I like to be able to plug the ANR headsets into ship's power, rather than having a battery box.
Re: ANR Headset Recommendations
Postby Murray Parr » Tue Jun 11, 2024 1:19 am
I am using Lightspeed Tango. They are wireless which I love. If you convert to the Lemo plugs, they are wired to the ships power, or you can just plug the panel interface into the ships charge socket (which I wired during construction). I just recharge mine at home though and they last many hours on each charge, but I also have the option of charging in flight. Not sure what the current price is but when I bought mine a few years ago, they were far cheaper than the Bose and are comfortable and light weight, ANR works great and seem to be good quality.
My other ANR set is Lightspeed Zulu purchased 20 years ago and still going strong except the wires from the headset are starting to fray the outer casing, been really happy with those too.
Murray Parr
WXB0015
Rotax 912ULS
MGL Explorer Lite
First flight May 6/23
RV9 builder (Sold)
Murray Parr
Postby WaiexB22 » Tue Jun 11, 2024 5:09 am
They aren't cheap, but I have the lightspeed delta zulu and I love it. It has the CO monitor which can be nice depending on what you are flying. Personally, I have always upgraded my set and kept my old set for anyone that wanted to go on a ride.
Robert
Waiex-B 0022
Yamaha Apex
Building
WaiexB22
Postby Tnhelm » Tue Jun 11, 2024 8:51 am
I have two Bose A20’s and two Zulu’s. One of the Bose I bought preowned online from one of the pilot supply stores which is a good value. Both the Bose I bought not blue tooth because I rarely ever used the feature. Buying preowned can save some dollars.
The Bose microphones do a little better in a noisy experimental type cockpit. In my opinion, the Bose has a very slight edge on noise canceling. That maybe more due to fit than electronics, I am not sure.
Regarding the Zulu, one advantage is it has an adjustable gain control on the microphone that the Bose does not have. I have found that the gain needs to be substantially reduced in noisy cockpits to minimize transmit noise. My MGL V16 Comm also has a microphone gain adjustment which needed to be reduced to minimize transmit noise, especially with the Zulu.
Bang for the buck, Zulu, however the Bose has a slight edge on noise control.
I have the Zulu’s in my 172, the Bose in my Onex. Regardless, they are both good.
Tnhelm
Postby Jester504 » Tue Jun 11, 2024 3:18 pm
I know I'm ignoring the "ANR" part of your question, but I have a Bose A20 and a QT Halo and I vastly prefer the QT Halo. The Halo is also vastly cheaper...
Jester504
Postby builderflyer » Wed Jun 12, 2024 9:45 am
Jester504 wrote:I know I'm ignoring the "ANR" part of your question, but I have a Bose A20 and a QT Halo and I vastly prefer the QT Halo. The Halo is also vastly cheaper...
I'll second Jester........I've used both the lightspeed zulu and the QT Halo in my Sonex and much prefer the Halo for noise reduction. It also requires no batteries and being "in the ear", doesn't bang against the side of the canopy.
Art,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,Jabiru 3300 #261
builderflyer
Postby DCASonex » Wed Jun 12, 2024 12:24 pm
If you sit a bit tall in the saddle (long waisted) The Clarity Aloft headsets provide more clearance to the canopy, are very lightweight and the ear pieces which are much like standard ear plugs, do a good job of blocking sound. Had a set for myself and an conventional ANR headset for my wife. She did not like the idea of the little ear plugs, -- until she tried mine one day. Then had to get a set for her.
DCASonex
Postby daleandee » Wed Jun 12, 2024 2:15 pm
DCASonex wrote:If you sit a bit tall in the saddle (long waisted) The Clarity Aloft headsets provide more clearance to the canopy, are very lightweight and the ear pieces which are much like standard ear plugs, do a good job of blocking sound. Had a set for myself and an conventional ANR headset for my wife. She did not like the idea of the little ear plugs, -- until she tried mine one day. Then had to get a set for her.
Agreed on the Clarity Aloft! I've had ANR sets and I personally find the Clarity Aloft to be naturally quieter than the ANR sets I've tried (microphone is excellent also). I don't need batteries and I can wear my large full brim sun hat when I'm flying. I wasn't crazy about the supplied in ear tips that came with the headset (they worked well enough) so I ordered some of the triple flange,"tree type" from here:
https://earphonesplus.com/
Easy to insert/remove, they work well, and tend to stay cleaner ...
Dale
3.0 Corvair/Tailwheel
daleandee
Postby Archer123 » Wed Jun 12, 2024 7:23 pm
I've used these for years... love em, Great price as well
https://www.quiettechnologies.com/index.php?route=product/category&path=66_59
Archer123
