by Area 51% » Wed May 29, 2024 11:08 am
Took delivery of my kits about a year ago. I assembled the rear spars and put them into storage till a couple of days ago when the wing structures required their installation.
Much to my dismay, the supplied spars are on the order of 1.7mm (.067in) narrower, flange-to-flange, than listed in the drawings. What that translates to is a really crappy transition from the rib flange to the spar flange. I'm no engineer, but it seems to me the wing skin needs to be able to rest flat against the flanges to give the hinges a solid base on which to attach.
If that wasn't enough, the angles of the left-hand spar flanges are inverted with the 11degree bend on the bottom and the 7 degree bend on the top. The right-hand spar has the correct angles, but is also undersized.
Any other recent kit deliveries experiencing these issues?
Tech has been informed.
Frustration Factor 9.0 here @Area 51% .
- Attachments
