fastj22 wrote:Here's my test plan. Take off and get at least 3000 AGL. Set my altitude bug to my altitude (virtual field elevation). Start a typical Vy climb simulating a power climb. 300 ft above the bug, pull the power (simulate engine failure) and execute a 180 turn keeping the plane in Vy using the LRI. How did it work? Low or high? Now do it again. This time increasing my turn rate to the point of stall/spin. Eventually spinning it. Repeat until I can just do the 180 turn without spinning. That will tell me the minimum altitude required to execute a 180 turn without an engine and without a spin.
Bryan Cotton wrote:Turn rate is proportional to the square of airspeed. Good to be as slow and steep as possible - without stalling of course. .
Rynoth wrote:Bryan Cotton wrote:
If you're going to impact terrain, here's you're mantra, remember it forever: "Wings level, don't stall". Do that, your chances to walk away go up by... a lot.
Darick wrote:Ryan,
I was on your website and see I have the same lift reserve indicator. In a week or two I'll be at the point of installing it and wondered if you any words of wisdom/tips on your installation? ...left wing, right wing, placement from wing tip, etc?
Thanks for any info.
MJHall wrote: I have not used this instrument, and suppose it would take some getting used to for us "old guys", but is probably worth it.
Users browsing this forum: Bing [Bot] and 13 guests
