Removing flywheel
Removing flywheel
Postby mccool » Sun May 19, 2024 9:49 am
I have to pull the sump on my Gen2 3300, (don't ask!!), and to do that, I need to remove the flywheel! #@$%%**!
So far I've heated the bolts with a 1500W heat gun, protecting the magnets of course. All per the instructions, but can't get the bolts to budge.
Anyone else been successful with this, and how did you do it??
mccool
Re: Removing flywheel
Postby Kai » Sun May 19, 2024 11:51 am
What kind of heat gun is that- electrical?
Sorry, but that won´t do it. Those bolts are secured with Loctite 620, which needs something around 150 centigrades on the bolt heads to let go-maybe even more. This means concentrated heat on each bolt head from either a propane torch or better still an oxy-acy one for quite a while.
Make sure you throw away the old bolts after you´re done.
Sonex A #0525- SG, DS.
Kai
Return to Jabiru
