EarthX Battery Kaput?
An area for non-builder owners to discuss issues that they may not be familiar with to increase safety in the second hand Sonex line market. Post things to watch out for and anything safety related for secondary owners here.
Re: EarthX Battery Kaput?
Postby Weatherpilot » Fri Mar 15, 2024 1:43 pm
I think I mean the master solenoid - on the firewall. oops
Greg Hubert
Sonex A #972 TD
Aerovee Prince P-Tip / Dual stick
Third Owner
Eastern Panhandle of West Virginia
Weatherpilot
Postby Bryan Cotton » Fri Mar 15, 2024 2:15 pm
Some discussion on the subject:
viewtopic.php?f=6&t=2009
Shows my mechanical solution as well as some low amp electrical solutions.
Postby Skippydiesel » Fri Mar 15, 2024 4:45 pm
FYI:
I stand to be corrected however in my experience a SOLENOID is an electromagnetic device for transferring electrical energy to mechanical. as in a starter solenoid. A RELAY is an electromagnetic device for switching on/off an electrical circuit.
Skippydiesel
Re: EarthX Battery Kaput? - chasing demons/gremlins
Postby Weatherpilot » Fri Mar 22, 2024 9:02 pm
Here is a close out to this one.
It wasn't the battery
wasn't the solenoid/relay
wasn't anything
One of the big lessons learned with a second or subsequent owner of a Sonex or any homebuilt.
What did the builder do and why.
Found that no "juice" was getting to the starter. Thought it was the relay, wiring, breaker. Was nothing of the sort.
There is a 5amp toggle on the panel. Unmarked. No indication of what it is for.
Wow! Threw the switch and voila the starter turned!
This has been a learning experience. Frustrating but glad it has been figured out.
Now to start this thing ...
Greg Hubert
Sonex A #972 TD
Third Owner
Weatherpilot
Postby BobDz » Fri Mar 22, 2024 9:41 pm
Anti - theft switch?
Bob Dz...
Sonex B, Tri-gear
N624DZ (reserved)
BobDz
Postby Weatherpilot » Fri Mar 22, 2024 11:03 pm
BobDz wrote:Anti - theft switch?
Could be
Greg Hubert
Sonex A #972 TD
Third Owner
Weatherpilot
Postby Skippydiesel » Sat Mar 23, 2024 3:48 am
Skippydiesel wrote:FYI:
No one took me up on this - I wonder why?
Some of the confusion in this conversation is due to the incorrect use of the word SOLENOID. Most often the writer should be saying RELAY.
I am as guilty as the next home mechanic, for using incorrect terminology. Often both the sender & receiver of the message know what each are trying to convey BUT when many parties are reading the same message, its best, if not deliberatly trying to confuse, to be precise by using the correct terminology.
Skippydiesel
Postby Area 51% » Sat Mar 23, 2024 6:55 am
That's why it's hard to talk to an engineer. They take everything so literally.
Postby Bryan Cotton » Sat Mar 23, 2024 9:20 am
There is a solenoid in every relay. Our starter solenoid does dual duty, pushes the gear forward and makes electrical contact. I didn't sense any confusion here.
Return to Second Owner Issues
