Panel design website
Panel designs, construction methods, and pictures
Postby fastj22 » Tue Jul 31, 2018 8:04 pm
A neighbor of mine just reposted his panel design website he created a few years go. Its free. There is a A-model template and I will be sending him specs for the B-model when I get my kit.
https://www.ehangar.org
Re: Panel design website
Postby Spaceman » Tue Sep 11, 2018 11:31 pm
This site is cool! I was looking for something just like that.
I uploaded a photo of my plans page with the B-model panel as an experiment. It works but it isn't too pretty. If you type in Waiex when searching for panels it'll show up. I'll do some photoshopping and upload a better version later.
Chris Paegelow
http://paegelow.blogspot.com/
Spaceman
Postby SnakePilot » Tue Mar 12, 2024 3:15 pm
Has anyone built or have an interest in exploring an all-analog panel for Sonex B/Waiex B with Center Stick with real gauges... with moving needles?
I'm an old school, former Comanche 260B owner/pilot who has a love/need for traditional gauges.
The standard minimum six-pack plus Tach, Oil Temp are most important. Depending on space, maybe Oil Pressure and Amps.
Waiex B Tail-dragger - 2850 Corvair Project
Coupe Top, Steam Gauges, Center Stick
Aluminum Main & Aux Tank
Fort Worth TX
N44YX (reserved)
SnakePilot
Postby XenosN42 » Tue Mar 12, 2024 3:55 pm
SnakePilot wrote:Depending on space, maybe Oil Pressure .....
Oil pressure is required, see: https://www.ecfr.gov/current/title-14/chapter-I/subchapter-F/part-91/subpart-C/section-91.205
-- Michael
OneX N169XE
XenosN42
Postby SnakePilot » Tue Mar 12, 2024 4:01 pm
Thanks! Tach, Oil Temp, Oil Pressure, Amps may be smaller gauges.
Fort Worth TX
N44YX (reserved)
SnakePilot
Postby GordonTurner » Tue Mar 12, 2024 4:05 pm
91.205 doesn’t apply to EAB. No instruments are required at all. If you later want to fly night or instrument, then 91.205 will start to apply per your oplims.
GordonTurner
Postby SnakePilot » Tue Mar 12, 2024 4:10 pm
Thanks, Gordon. How are you getting along with your build with the Corvair? I've watched your vid on YouTube several times.
Fort Worth TX
N44YX (reserved)
SnakePilot
Postby XenosN42 » Tue Mar 12, 2024 6:13 pm
GordonTurner wrote:91.205 doesn’t apply to EAB. No instruments are required at all. If you later want to fly night or instrument, then 91.205 will start to apply per your oplims.
You are indeed correct, it's not required. IMO not installing one would be very unwise.
-- Michael
OneX N169XE
XenosN42
Postby SnakePilot » Tue Mar 12, 2024 6:24 pm
Agreed! Thanks again
Fort Worth TX
N44YX (reserved)
SnakePilot
Return to Panel
