Hi George,
I've heard rumors that the new Sonex secondary ignition module shuts down after some period of inactivity to keep from burning up coils. Does anybody know if that is true?
Anyway, let me try to explain the way the secondary worked back in the day on my AeroVee. It might at least provide some food for thought. Since I owned an AeroVee Sonex LLC has changed coils and obsoleted the old trigger module. Things might be a little different now. But here's how mine worked.
While the secondary ignition switch is on, there is 12 volts on one side of the primary winding. The other side of the primary went to the ignition module. The ignition module side was basically GROUNDED while the trigger magnet was NOT aligned with the sensor in the trigger module. When the trigger magnet WAS aligned with the sensor in the trigger module the ignition module side was OPEN.
So, for most of the time the ignition module side of the coil was grounded and the coil was charging, then, when the magnet passed the (hall effect) sensor in the ignition module, the ignition side of the primary opened up. Much like a set of points opening up.
Here is a pic Chris Madsen posted a long time ago that illustrates whats going on. The pic shows the current passing through the primary of the coil. The current jumps to zero when the magnet passes the sensor. This causes a large induced voltage in the coil secondary winding and the plugs (should) fire.
![Image](https://i.postimg.cc/KYKQRBwF/Secondary_Ignition_Coil_Current.png)
Here is a pic of the voltage on the ignition module side of the coil primary when the ignition module opens the circuit.
![Image](https://i.postimg.cc/tRFCyZx7/Sec3.png)
If you compare the two pics, when the current in Chris's pic goes to zero you can see the large voltage spike on the voltage pic. That spike starts the spark event. Then there is a flat spot on the voltage pic. That's while current is actually "jumping" the plug gaps.
Next comes the ringing on the voltage pic. That when there is no longer enough voltage on the coil secondary to arc the plug so the current in the coil secondary suddenly stops. That sudden stoppage reflects back on the primary much like what happened on the secondary when the current in the primary suddenly stopped.
Anyway, what comes next, after the ringing, the ignition module side settles in at 12 V. At that point the circuit is still open and no current is flowing in the coil primary so all you see is the 12 V power on the other end of the primary winding. That continues until the magnet clears sensor. At the very end of the voltage trace you can see the magnet clear the sensor and the module side of the primary is again grounded and the process repeats.
For dual plug coils to fire both plugs at the same time there is only one secondary winding. So, the plugs are in series with the secondary winding. In theory the secondary winding is "sucking" current from one plug and "pushing" it to the other plug. Not always the case though. If the coil arcs internally or if there is enough inner-winding capacitance (or some such techno babble) there may be enough current/charge available to fire only one plug.
Enough of that. So what to do.
Assuming you have done whatever you deem appropriate to ensure that you can fiddle with the prop while the secondary ignition is on without the engine firing, I would start by seeing if you can fire the plugs by exercising the ignition module by hand. You can do that hooking a volt meter to the ignition module side of the coil primary and moving the prop so as to make the trigger magnet pass in front of the sensor. You should see 12 volts (after a healthy spike) while the magnet is passing the sensor and zero volts while the magnet is clear of the sensor. If that works, then you have a good idea that the ignition module and trigger magnet are OK. This assumes the new ignition module works the same as the old ignition module.
Wes
