by MichaelFarley56 » Fri Feb 21, 2014 8:47 am
Great questions Mike. I'll be the first to admit that I'm not anywhere near an expert on the AeroInjector or how to get it "perfect." I've been flying behind mine for almost 2 years and close to 100 hours now, and have to admit it took me a little while to tune things to my satisfaction.
Ultimately, what I've personally found on my engine is that the standard, straight taper on the #2 needle I use isn't quite optimal. Even though it's not terrible, at some point I'm going to experiment with the needle itself a little, just like Jeff Schultz described on his webpage. At this point I'm having good luck by tuning the needle to wide open throttle EGT readings to get them where I want them, and then using the mixture needle for other adjustments. Like the factory and everyone else has said, a small turn on that needle can make a big difference. I wouldn't make more than 1/4 turn adjustments at a time. Also, I do agree that there's a difference between having the cowling on and off. To get a good initial "rough" tune leave the cowling off, but once you're into the fine tuning steps the cowling needs to be in place.
For me personally, my goal is to run my engine at wide open throttle (either in a climb or tied down well) and see my hottest EGT run up to around 1200 degrees. I used to see 1300-1350, but the factory told me that's too lean for climb which I agree with. I'd really like to see 1100-1200 on the climb but things get too rich in cruise and during descent. So, when I tune my needle, that's my goal. It was important for me to lean while flying my Waiex that I couldn't simply push the mixture to full rich for the whole flight like the old Cessna trainers; I generally make a mixture adjustment after every big power change. Leaned for taxi, full rich on takeoff, leaned just a little in cruise, leaned some more during approach, etc. etc.... For me that's not a safety concern, just something to get used to.
I completely understand the concern with this Florida accident and know I don't need to say it, but remember an engine stumble can be a lot of things. Proper fuel delivery can certainly be an issue, but so can the ignition system, spark plugs, air filter, a valve issue, etc. I landed last weekend and did an ignition check as I taxied in since it felt like my engine just wasn't running quite as smooth as normal. Turned out my engine ran really bad on the secondary ignition which I traced to a bad secondary ignition coil. I just installed a new one yesterday and even though I didn't fly, it ran much better during a ground run. Point is, let's be patient on that accident before we jump to conclusions. It may very well have been a carb issue, but at this point we just don't know.
Robbie I couldn't agree more with the need for data. This is going to be a tough one though; I'm not sure how many people can quantify carb issues (or any other issue for that matter). You asked me about "burps" on my AeroVee; I had a lot early on which I ultimately traced to an older style MGL fuel flow sensor causing blockage issues. Once I removed that, I haven't had a single one since.
I wish there was a way to measure this data. The only thing I can come up with to start is to create a poll to see who all is using AeroCarbs/AeroInjectors and see how many people are having or have had issues. It doesn't give us much info though. This is a tough one.
Waiex #0056 - N569KM
Jabiru 3300A #1706
