by pappas » Mon Feb 12, 2024 11:52 am
I have had both the A and B models. The A with the vertical split and the B with the horizontal. The horizontal split is sooooo much easier to work with and to take off and replace when the plane is done.
The fiberglass is a giant pain, but it is not difficult to do. The lay-up process is fast. The finish sanding is torture for me, but I do it because it is much easier on the wallet than buying a new cowl that you will surely have to do some glasswork on anyway.
Install the cowl as best you can, screw in a few scrap aluminum strips that bridge the gap across the bottom to hold the cowl together. Place the strips on the inside. Sand 2-3 inches outboard of the seam, and lay up 2-3 long strips of glass and resin across the seam from the firewall to the front of the cowl. After it sets up, usually the next day, mark your centerline and cut the cowl apart along that centerline. The fit will be perfect. Then you need to sand and finish the repair. Most of us have done it. Plus you will have a new skill that you didn't want!
Frankly, after having both cowls, if I had the vertical cowl on a new build, I would glass the whole thing together and remake it with a horizontal split.
pappas on Mon Feb 12, 2024 8:30 pm, edited 1 time in total.
Lou Pappas
Phoenix, AZ
RV-7A Flying (2024)
Waiex B Turbo (2016)
RV-8 (2009)
Waiex Legacy 3300 (2007)
Hiperlight SNS-9 (1991)
Falcon Ultralight (1989)
