So the big dilemma is locating the parts before drilling holes in the firewall. I had these things to consider:
1) Clearance for my feet
2) Clearance for the control cable with respect to the rudder pedals
3) Clearance on the engine side of the firewall
I took my drill template, temporarily riveted the cable end bracket to it, and taped it in place. Seemed ok from the inside, so I used a center punch to mark where I would be holesawing the 1.75" hole. Then I marked the firewall on the engine side with a sharpie on the center punch dent. I taped my simulated firewall that was in my videos to the real firewall. I taped a piece of paper to the 1.75" hole with a hole in the center, and centered that on my mark. Immediately I had clearance issues. The valve body hit the engine mount. Also my mixture cable was going right through the air inlet tube. So I figured I could move it up about 5/8", and inboard about 1/4". I tried that out and it seems good.
- prototype cable routing.png (483.66 KiB) Viewed 1683 times
For attaching the valve body, I put nutplates on it. Would be a major pain to put nutplates in the firewall with the floor installed. So I'll have to screw it on from the inside. I'm using #8 screws.
- valve body with nutplates.png (505.29 KiB) Viewed 1683 times
Two of the mounting screws pick up this deflector I made. Idea is to send the hot air largely downwards, rather than shooting directly out.
- deflector.png (508.89 KiB) Viewed 1683 times
So I am about to pull the trigger on this and install it. So far my parts weigh 0.256 lbs, minus the control cable, 6 screws, 4 rivets, and a short piece of scat tubing. So probably about 1/2 lb. If I can save that in clothing I have to wear then I have definitely won!
