Skippydiesel wrote:Looking for others experince using flaps -
My Sonex Legacy has the standard (large flaps) arrangement.
I only ever use flaps 1&2 - 3 doesn't seem to do anything much and is very hard/heavy to select.
I, as you would expect, makes by far the most change to low speed handling.
2, just seems to add drag - which is useful on late final.
Stall speeds - 40 knots clean, Flap 1 -37 knots , Flap 2 - 37 knots, Flap 3- 37 knots
sonex892. wrote:
I have not flown with the acro ailerons but imagine they would have to be quite a bit heavier than than than standard ailerons. I think I would prefer the lighter control forces.
Skippydiesel wrote:I only ever use flaps 1&2 - 3 doesn't seem to do anything much and is very hard/heavy to select.
Skippydiesel wrote:2, just seems to add drag - which is useful on late final.
sonex892. wrote:I have not flown with the acro ailerons but imagine they would have to be quite a bit heavier than than than standard ailerons.
sonex892. wrote:I do have a couple of hundred hrs in a Sonerai, they have shorter chord, full span ailerons. It was both lighter and crisper, faster roll rate than the Sonex. IMHO Shorter chord full span ailerons / flaperons on the Sonex would be awesome.
Users browsing this forum: No registered users and 33 guests
