pfhoeycfi wrote:
In the final analysis what do you attribute your improvements to? Are the oem springs worth trying? Did you have to modify them? Curious can you replace the springs without draining the oil? I've had the oil drained each time I've pulled the springs and plungers.
BRS wrote:Bryan hope you don't mind me tagging this onto your thread. Just didn't seem worthy of a new one.
OK, Summer is gone but I've still been fine tuning my Sonex-A w/Revmaster. The new Rotec MKII is amazing (not for this thread though) the other pesky item has been warmer cylinders than desired. FINALLY figured it out. Yes, uneven fuel distribution was part of it - solved. Still they were not where they should have been. Making the change pictured below made a considerable difference.
For the original installation that top plate was really just a safety wire holder to keep the bottom (not shown) plate in place. But it it is clear that most of the cooling air would sneak around the side instead of going through the fins. I was unsure how much difference this would make. Now I know, it makes a lot of difference.
Users browsing this forum: Google [Bot] and 12 guests
