GordonTurner wrote:Wow. Are you sure you have the correct alignment? I guess you can extend that if you swap them every oil change. Any opinions if it would be ok to just swap the whole wheel, in which case the direction of rotation would be reversed? Is there a bearing problem if you do this?
Gordon
Bryan Cotton wrote:Started swapping my tires tonight. This is about 110 hours or so.
tps8903 wrote:Is the wear on the outside or inside of the tire? Mine was the inside of the tire. The extreme toe out was dragging my gear down trying to spread the tires. I would assume you have a bit of an opposite issue with too much toe in.
Skippydiesel wrote:I think it would be helpful if you gave your tyre pressures - On my new Sonex Legacy (45 hrs) I am using 35 psi, operating almost exclusively of grass and so far no sign of unusual wear (actually tres still look new)
Bryan Cotton wrote:Skippydiesel wrote:I think it would be helpful if you gave your tyre pressures - On my new Sonex Legacy (45 hrs) I am using 35 psi, operating almost exclusively of grass and so far no sign of unusual wear (actually tres still look new)
45-55 psi.
Skippydiesel wrote:Thanks Bryan - that's quit a wide pressure range for such a small tyre. My tyres are Goodyear Flight Custom III, 5.00-5, if failing memory is good Max 50 psi.
Would the tyre make/model change your recommendation?
Bryan Cotton wrote:Typically when I fill mine I go right to 55 psi. They never stay there, but they don't seem to go below 45 psi. So I fill them to 55 and leave them alone as long as they are at least 45.
