Bryan Cotton wrote:We are about to replace the tires for the second time at 185 hours or so. We had a blowout on the first set. I suspect alignment and plan to measure it carefully when ballasted up. I was going to put steel rods under a steel plate to let the gear spread out, same idea as a grease plate. No advice yet, it's going to be a winter project.
bvolcko38 wrote:What tires are you running? What tire blew out?
tps8903 wrote:When I got back while looking at the plane I felt like the left main gear might have a bend in it, and that might be causing alignment issues? I'm going to pull it off and check it against a straight edge this week. Does anyone have advice for straightening a main gear with a press that has done it?
