GraemeSmith wrote:
After a careful read of the cowl instructions - I enlarged the bottom outlet by nearly 50%
achesos wrote:
Hi Graeme,
After some frustration and research, I need to revive this post.
What is your cylinder baffle configuration? My heads are outside the Sonex "baffle box" setup, so I'm hesitant to start cutting into the cowl since it doesn't seem like they are getting any forced cooling anyway.
I wish there was an easy way to figure the statistical % of Model A Sonex with AeroVee engines that modified (increased) the outlet cross-section?
I'm chasing a solution to only balance CHTs (right rear is hottest of course) but decrease them all.
Sean
