T41pilot wrote:Bryan Cotton wrote:Good point Keith. Does anyone know what the voltage and current out of the stator is?
approx 23v to 27v AC at 3000 RPM when measuring across the alternator leads by themselves disconnected from the regulator. Just did that awhile back when checking my regulator circuit. That would be no load so current not a factor with that measurement.
LarryEWaiex121 wrote:Bryan,
Added a ground to the regulator rectifier and ran engine on ground for about 5 minutes at up to 3000 rpm.
Battery voltage never budged.
The plane has an older Stratomaster Infinity E-1 Engine moniter. It displays voltage, flight time and hobbs when engine not running. The only way to see voltage after engine running is to turn knob back two clicks counter clockwise. Bizarrely, the battery measures 12.94 off the charger at the battery. With the engine running and panel operating, its normally about 12.5-12.6 at same level of charge. Seems like considerable loss in the system?
After about 5 minutes of running at various speeds and voltage never moved so I'm thinking there is no charge.
I'm spoiled by my Dynon Skyview in my Waiex because it shows voltage and amp draw at all times. No amp draw on this Onex setup. No shunt to measure draw.
I'll have to keep tinkering on this. Plane is great but having to charge battery every hour isn't the answer.
Larry
tps8903 wrote:That being said. I went back to the Sonex VR. The most I ever see on my MGL is 13.2V, but it usually hovers around 13.0V. Interestingly, the MGL V10 radio I have also displays voltage on the bottom bar. That one shows 13.4V regularly. I tend to believe the radio Voltage as it's closer to the measured voltage on the battery with a volt meter.
LarryEWaiex121 wrote: That and a light coating of dielectric gel and I appear to have a charge going on.
Larry
Waiex 121YX and Onex 752MR
LarryEWaiex121 wrote:TVoltage dropped to a low of 12.5V before take off to a high of 13.0 while cruising with Stratomaster Infinity, Velocity, GRT Mini EFIS, Microair 760 com and Trig 22 transponder with ADSB-out.
I find that tripping the secondary ignition off at altitude really helps with battery voltage recovery.
I turned on the wing strobes about 15 miles from my home airport and in the time it took to cover those 15 miles into the pattern, voltage dropped .2V to 12.7 in the pattern. Not to shabby.
Users browsing this forum: Google [Bot] and 11 guests
